Anyone running this?
It is marketed for a 1g so I figured that I would ask here first in case there is anything that I am missing e.g. bigger length between regulator and firewall etc.
I like the plug and play nature of the setup.
Thanks
Well i have it just waiting to install it.its a nice setup, ran a similar setup but the maperformance version of the kit with pushlock lines on my old 2g.
No theres plenty of line it's pretty plug and play just read the instructions
snohacking
Menomonee Falls, Wi
ran that set up on my 2g and then my vr4. Works good just have to fit a spot on the firewall to mount it. You will also have to look up putting ss an lines fittings on. They give you an section of line, you measure it,cut it then put the fitting on. Its not hard once you know how to do it. overall its a nice kit.
5OF2k
colorado springs, colorado
I have one of their firewall mount line kits on my car, but I run the Aeromotive FPR instead of the fuel lab unit. THe lines are good though, they last a long time and seal well. Just be sure to tephlon tape the threads on the fittings, of course.
-Jake
toybreaker
iconoclast
Do NOT put teflon tape on AN fittings.
... especially on fittings used in the fuel system
raptorWagon
Oak Harbor, WA
Quoting 5OF2k:
-Jake
Teflon tape is for Pipe fittings not flared/Compression Fittings such as AN.
I was going to say there are cheaper kits, but the preassembled lines are nice. No pricked fingers and swearing to get it done. Although that is the fun part.
theevozero
Odessa, Texas
*edit* ^nevermind^
I didn't realize they were all preinstalled. That blows. I made mine fit. I see the dilema.
Quoting 5OF2k:
What's the harm in sealing the threads like that?
The threads aren't doing the sealing, the flare inside the fitting is. So using teflon tape is unnecessary.
citymunky
Chesapeake, VA
Quoting turbowop:
Quoting 5OF2k:
AN fittings were designed for Naval Aircraft back in WWII. They are still being used on aircraft today with operating pressures at high as 3000 PSI and we don't use teflon tape. Like Wop said the flared mating surfaces make the seal.
