any short shifter
a2vr4
Ann Arbor MI
a 1g short shifter. /ubbthreads/images/graemlins/dunno.gif If I understand you correctly, the shift arm and possibly new bushings should be all you need. Are you asking about a stock 1g shift arm(which is shorter then the stock gvr4) or an after market "short throw" shift arm?
~Brian A. Moreno
Brunoboy
San Bruno,CA Home of SFO
at the end of it all, if a stock 1g shifter fits in the car no problems, i THINK a short shifter made for a 1g would fit no problem as well.
Whoodoo
Binghamton, NY
Search...
A 1g shifter with be a direct bolt in, but may be too short. I modified a 3kgt shifter in order to get a shorter throw without making the shift knob too far away.
oldman_tau
cerritos,california
thanks for the reply guys. because i tried the 1g shifter and i couldnt shift to 3 and 4th gear it kept on hitting the base of it. thanks
a2vr4
Ann Arbor MI
sounds like an adjustment issue... check in if you are still having issues /ubbthreads/images/graemlins/smile.gif
~Brian A.Moreno
