Another offset question!
Checked the known rim and tyre graph and searched but with no luck just want to know will a 17x7+32 offset and a 17x8+32 offset fit the GVR4?
EMX5636
Bucks County, PA
I would go 215 to 225-45 on the 7" wheel. Could go 225 or 235-40 or 45 for the 8" wheel. Shouldn't have to roll anything. Just might have to bring the front camber in a tad. Maybe -1 or -1.5*
mitsuturbo
Near Seattle, Washington
If you're looking at buying "staggered" wheels, I'd advise against it. If you're dead set on getting something like that, you're going to have to find a tire that fits BOTH widths of wheel properly. Not a huge deal, but something to consider.
I don't know how it would work out when it comes time to rotate your tires, either. That's something else that might be an issue. Or just never rotate them?
7" wide in front and 8" in rear might look okay, but rotating them so that the 8's are in front might wind up looking a bit off.
