Aftermarket Support
Gilga5
Active member
Worcester,Ma
It has been quite difficult to find lowering springs or coilovers for fwd galants. I know Malaysia and Philippines have tremendous support but how about U.S?
I know Vr4 has. But anyone know of any sites to find parts?
Bstiles
Member
Indianapolis
There aren't any options really unless you go full coilover or piece together something custom, sadly.
Google dssa, jnztuning, stmtuned. You'll find the coilovers there
Gilga5
Active member
Worcester,Ma
I greatly appreciate your response and info! I'm still fairly new to the mitsubishi game since my 90 galant was passed on to me. Are they consider 1g or 2g?
Imback
Suffolk,NY
Feal,D2.BC and k sport all make coilovers for our car. Springs have been discounted last time i looked.
moduleunknown
Elk Grove, CA
Wonder if the Muellerized Ohlins, adapted from the Evo to work for the 1g DSM will work on the GVR4 - don't see why not:
I'd call them, as I doubt that pricing is still accurate.
Short answer, yes.
I have Ohlins Road & Track coilovers for a CT9A installed on my E39A.
To make them bolt in, I used the following items: SCE adapter kit for the rear lower mounts, E39A camber plates from BC for front upper mounts (replacing the CT9A plates), and some slightly longer camber adjustment bolts (sourced from McMaster-Carr) as the BC plate is a couple mm thicker.
