Quoting 447galantvr4:
What would be the best way to have a 1 to 1 ratio fuel pressure hooked up on a GVR4, Factory control unit or off of the turbo pressure tube? Thanks for the help.
Depending on what you mean, the "turbo pressure tube" is no good either. You need to plumb the AFPR into the intake manifold, after the throttle plate. Otherwise your AFPR won't really be seeing as much vacuum as your head and you'll run rich when not in boost.
