AEM EMS Placement
I leave my dangle. I will just tuck it under the mat. The only other thing you could do is machine a plate and stick it in the factory location with a little creative placement.
Galantvr41062
plymouth, MN
When I had my stock interior the AEM did fit in the stock ECU location. Now I have a plate that is bolted to the inner fire wall that it is mounted to.
~John
belize1334
Bozeman, MT
Will it not fit way behind the radio where the DSM ECU is? I had a stereo module in there and I seem to remember that there's lots of room. There's a kick panel that sits next to the passenger's LEFT foot which gives you access to that area and I bet you could find room for it.
Jazzyjay
Charleston, SC
ok I will try the factory location, the floor and dangling is not a option. I had it mounted behind radio in my talon but don't thing wires will that far because the Galant factory ECU is in the passenger side kick panel
iLLeffeKt vr-4
NYC
Put it where the factory ecu is located. You don't want that on the floor in plain view unless you're looking forward to having your car broken into.
