91 4g63
valdez4o8
New member
gilroy
I wanted to ask and see if a 4g63t from a 91 galant fit in an eclipse gst. Any info would be helpful thanks
valdez4o8
New member
gilroy
Yea but my concern is that the vr4 is a 1g 4g63 with ob1 the eclipse is a 96 wiith ob2 making it a 2g. Thats where um stuck
transparentdsm
Cherry Hill, NJ
you need special harnesses and a lot of swapping over parts. its not hard if you know what your doing and you will also need DSMlink to get rid of the random misfire. i have swapped a 6bolt into a 99 gsx before, not hard to do.
BENE38A
New Zealand
also you would need a 2g or 7 bolt transmission because the front and rear mounts bolt to the transmission on 2g 7bolts not on the block like a 6 bolt 1g or you could get custom crossmembers to use the standard mounts and a matching transmission.
LIV4PSI
O-H-I-O
He doesn't necessarily need ECMlink. I never got a random misfire cel when I did my 6 bolt swap. Only needs one harness since there is no crank sensor on a 6 bolt
EMX5636
Bucks County, PA
95-96 are the ones I believe you need to swap the firing order. Since the cam sensor is on the other end of the camshaft, it is inverted. Not a big deal, but do a bit of research of a 6 bolt in a 2G. Tons of info out there.
This should get you started at least. click Don't pay attention to the oil pump/front cover modifications. That isn't required unless you wanted to run a 2G crank sensor, and now as the years have progressed, Kiggly Racing builds a setup for a 1G front case. here
The Galant engine is (besides a couple small things) identical to a 1G DSM, you will find a lot more info that way. This is a good write up. web page
