3kgt brakes
91vr4394
Active member
Altoona,PA
I been thinking about doing a 3kgt brake upgrade on all 4 corners of my vr4..the reason for this post is im not quite sure on what all i need to purchase..any info would help thanks
broxma
San Antonio Tx
What you would need to purchase is a way to keep the rear brakes from locking up every time you touched the brakes. There is a valid reason they put the bigger brakes on the front. Unless you mean the 300GT rear brakes in which case, there is no point, they are the same essentially and don't have the E-Brake accommodations needed.
For the fronts, you need the calipers, pads, rotors(5 lug is easier to get) and the caliper brackets from from Garfield.
/brox
H05TYL
Wgtn, NZ
discs and calipers, then you'll need to have some brackets made up to mount the calipers to the hubs - you can fit the gto trailing arms in the rear complete with the rear calipers/handbrake setup - you'll probably want to get some 5-stud hubs for the front to match.
Then of course you'll need new wheels with the right spoke shape to clear the front calipers (and suit the 5-stud hubs of course)
