3 bolt lsd?
MellowVR4
Milwaukee, Wi
How can i tell if the diff i wanna buy is a true LSD, whats the number supposed to be on the 3bolt diff to make it LSD. looking to buy one just wana make sure.
JSchleim18
Long Island, NY
I Don't recall the numbers but for one they should be easy to search on the forum. Also, if it is LSD, it will say Viscous LSD on the sticker.
belize1334
Bozeman, MT
Should say "Viscous LSD - B17" on the rear cover. Also, one of the axles will have a longer splined section than the other.
belize1334
Bozeman, MT
Unless the rear cover has been changed out. Make sure that the axles are uneven. Also look in through one of the axle holes. There should be 3 splined regions on an LSD vs. just two on an open diff. The two outer splines are for the main axle drive and then there's a third splined region toward the middle which engages the secondary splines on the Driver's side axle and operates the LSD.
H05TYL
Wgtn, NZ
could it be B15? does it have the hole for the 4ws pump?
I have a pair of 3 bolt mech lsd's and they have B15 on the rear cover, no 4ws pump and the fill plug says "use only lsd oil"
MellowVR4
Milwaukee, Wi
how do you change the rear diff pinion bearings, diff bearings, seal. i tried searching but i could not find nothing, just trying to change them before i put it back on.
Olson
Moreno Valley CA
Quoting H05TYL:
Deff says b1g
