1st time at the drag strip need advice
yeti
san diego california
Ok so the galant probly hasn't raced in over a year so what should I replace and lookover before going to the track
Any leaks, tire pressure, might wanna try to run your empty so u can add race gas for the track then turn up the boost a lil more. My 2 cents..
yeti
im replacing whats left to do as soon as my afpr and fuel pump get here.
my only other leak is from injector seal and BISS screw.
(everything else i know is fine)
and should i go get new differential fluid and new gear oil?
RedTwo
New Zealand
Check the accelerator initiation device. Ensure the base plate fully extends and connects the pedal with the floor /ubbthreads/images/graemlins/grin.gif
cheekychimp
East Sussex, U.K.
Yeah ... I actually don't do that anymore, I think there is something wrong with my car. The closer that pedal gets to the carpet the more the cabin gets filled with a noxious odour ... and screams, lots of screams!
yeti
should probably clean the HAIR OUT OF MY TURBO, /ubbthreads/images/graemlins/tongue.gif you know like a vacuum??!?!?!?!?!?!?!?! /ubbthreads/images/graemlins/tongue.gif
