1g brake calipers
Whats up guys. I have a NOOB question here and i tried to search it. I know the brake line hookup in a different location but will it still work on a GVR4?
Dan D
Brownsburg, IN
I had to replace one of my rears with an eclipse caliper. It functioned fine, but the e-brake attach was different. I think it was from a FWD.
Thanks, my bleeder valves have environmentally welded to the caliper and no buddy carries the gvr4 calipers. There is a good set of 1g calipers in the J-yard.
broxma
San Antonio Tx
The position of the bracket which holds the E-brake to the caliper is different and interferes. If you are crafty, you can modify this bracket and make it work. It is a bit of a Pain and took me a while to figure it out but that's what I did. I did however only do it to one side and then shortened the cable under the center console to make up for it. My E-brake is totally fine with only one working and passes the brake inspection.
/brox
If the calipers come from an AWD they should be identical. When I did my 4-bolt conversion I dropped an entire subframe (hub to hub, brakes included) out of a 1993 eclipse an the E-brake cables hooked to those calipers with zero modifications, look and function the same as stock.
I didnt get to it today. Ill go pick them up after work and install them. Ill post a tech article if all goes well. They are fwd ones too.
Wizardawd
Franklin, NC
Correct, 1g AWD calipers are the same. 1g FWD (Turbo or NT) have different mounting for the e-brake.
Wiz
