1991 Galant VR-4
238/2000 full "resto"
238/2000
Specs
Ownership Status
Currently Own
Year
1991
Production Number
238
Mods-Power
hta68 fp turb
2150cc ifc injectors
-6 AN fuel lines
magnus fuel rail
3" trubo back magnaflow
fuel pressure regulator
speed dense
mishimotto fans / radiator
ets front mount
custom intercooler piping
tial blow off valve
aermotive fuel pump
Mods-Drivetrain
stock trans / transfer case
act 6 puck clutch
act race fly wheel
dss aluminum drive shaft
shift cables
brass shifter / cable fittings
all new bearings seals and hubs
5 lug conversion
4 bolt rear
refreshed calipers
drilled and slotted rotors
power steering / abs delete
stainless rubber coated clutch / brake lines
jxb bearing carrier
Mods-Engine
268 / 272 brian crower cams
refreshed head
refreshed motor
balance shaft delete
arp head studs
arp cam tower bolts
boosted fab motor / trans mounts
kiggly hla pressure regulator
Mods-EMS/Tuning
v3 ecm link
Mods-Handling
ndd front / rear sub frame
ndd manual rack
ndd control arms
ndd mustache bar
d2 rally asphalt suspension
Mods-Interior
jbl speakers
alpine headunit
pioneer amps
10" sub
killmat sound deadening
gauges oil pressure, boost, water temp, afr
Background/Plans
Its been a journey so far, plans continue making progress, full "resto" started Aug 22', dyno day coming soon will post updates
https://www.galantvr4.org/threads/238-2000.38256/ " resto"
Car information
Added by
bcallahan92
Views
78
Last update
More in 1991-1992 Galant VR-4
