FS: Performance head
chucklesas
Dayton, OH
The valves measured out to be stock size (34mm intake, 30.5mm exhaust).
+Ferrea Beehive Valve Springs w/ titanium retainers
Specs:
- Spring O.D. - 23.87mm / 28.07mm
- Spring I.D. - 14.73mm / 18.85
- Seat Pressure - 90 lbs. @38mm
- Open Pressure - 225 lbs. @28mm
- Rate Inch - 342 lbs.
- Coil Bind - 23mm
- Max Net Lift - 135mm
- Spring Material - PAC Alloy
+Topline Revised Hydraulic Lifters
+New valve seals
+FP3 Intake Camshaft
+FP3 Exhaust Camshaft
+Fidanza Cam Gears
I would like to get $1000 obo.
chucklesas
Dayton, OH
Image bump.
Price is OBO.
chucklesas
Dayton, OH
Bump. More pictures here: click
chucklesas
Dayton, OH
PACKAGE Deal.
Cylinder head (specs above) and 4G64 6-bolt crank. Perfect combo for a stroker setup.
All for $1000 obo.
