Sorry to bother for this..didn't see it in a search.
What's the pitch for the 8mm exhaust manny studs.Also, I broke the stud coming out of the 14b to the O2 housing - anyone know the size of the stud/nut?
Thanks, Kevin
ok yeah i need to go to a hardware store and pick up some stainless studs for myself....so ken says the length of the stud is 40mm. my question is how much of that 40mm is allowed to go into the head. when i was removing those old studs from the head, it didnt seem like that much of them was actually screwed in there. so is there a limit to how much you can screw into the head?
what i will be doing is buying stainless studs from the hardware store that have heads so i wont have to go with the stud/nut deal as they are stock on the car.
there are 2 threaded sides of the 8mm stud, the short side goes into the head, only about 10mm of this is threaded, then there is a non threaded part that will stop the stud from going any farther. so, maybe 12mm max can go into the head.
