Galant VR-4 Forums » Galant VR-4 » General VR4 Discussions » E85 question
E85 question
Terrance362
needs moar imput
565/2000
Galant VR-4 org Post #: 1245315 posted 02/09/19 06:38 PM     Remind Me!  Send Private Message   Edit Post
In the mist of changing my street car over to e85 and possibly changing my lines from the tank to -8 and -6. Do I need to change them or can I get by without changing them?
Feel free to tell me your e85 setup
Edited by Terrance362 (02/09/19 06:41 PM)
Posts: 346 | From: Winston-Salem, NC | Member Since: 08/14/06 | IP: (2606:a000:1018:4) | Report this post to a Moderator
G Galant VR4.org Moderator
JDM Unit
486/1000
Galant VR-4 org Post #: 1245318 posted 02/10/19 02:40 PM     Remind Me!  Send Private Message   Edit Post
I've been looking for a small 6" rubber fuel line that is submersible in e85, no luck.
www.japanesenostalgiccar.com
www.nostalgic.co.jp
Posts: 8876 | From: zompton | Member Since: 02/24/04 | IP: (75.86.151.204) | Report this post to a Moderator
JNR
20/1000
Galant VR-4 org Post #: 1245353 posted 02/13/19 01:11 PM     Remind Me!  Send Private Message   Edit Post
Neoprene or Buna-N rubber is compatible with ethanol.
Posts: 9748 | From: ca | Member Since: 04/23/04 | IP: (2600:1012:b02e:a) | Report this post to a Moderator
Eager Beaver
Galant VR-4 org Post #: 1245471 posted 03/01/19 11:07 AM     Remind Me!  Send Private Message   Edit Post
Great primer on what to look for in terms of ratings, incompatibilities and what not.
https://www.hemmings.com/blog/2014/12/05/tech-101-fuel-line-hose-what-you-should-and-should-not-use/
I've seen it before, but lucked onto it again today when you asked these questions.
C53A 1 of the ~1500
Posts: 1599 | From: THE Ottawa | Member Since: 03/05/05 | IP: (198.84.218.38) | Report this post to a Moderator
Eager Beaver
Galant VR-4 org Post #: 1245472 posted 03/01/19 11:11 AM     Remind Me!  Send Private Message   Edit Post
Be aware that if your fuel system seeing X amount of boost, it will be rising one psi per lb of boost, so that doesn't leave much of a window or outright surpasses 50 psi rated lines.
I think that put you in nylon or the 30R9 category as listed, but not sure if that means pushlock fuel hose, but likely that is it. Not supposed to need clamps on that fuel line, but they mention clamping ... but maybe they mean a crimp like an ac pressure hose, but with pushlock hose. It is essentially pressures that AC hoses would see.
C53A 1 of the ~1500
slugsgomoo
god hates stupid people
461/1000
Galant VR-4 org Post #: 1245476 posted 03/01/19 05:50 PM     Remind Me!  Send Private Message   Edit Post
I'm running PTFE AN braided hose on my car, -8 from the tank to the firewall, and then mostly factory return.
While I haven't been running E85 on the old motor, the fuel setup is unchanged, and with base pressure at 50psi (because tiny injectors (that are getting replaced)), I was seeing peak fuel pressure of 77 PSI, and nothing blew apart Though frankly, once you get to the regulator, the output side of that should be much, much lower pressure.
-andrew
{witty signature}
2015 Triumph Tiger 800 XCx
2014 Ford Focus ST
Posts: 3646 | From: Bremerton, WA | Member Since: 10/16/03 | IP: (192.195.4.32) | Report this post to a Moderator
strokin4dr
1280/2000
1135/2000
Galant VR-4 org Post #: 1245510 posted 03/05/19 06:54 AM     Remind Me!  Send Private Message   Edit Post
I ran into the issue of the factory return being too small for a walbro 450. I am waiting to install my fuel pressure sensor to confirm suspicions but everything is pointing to that being the case. When running E85 it wasn't an issue but when going back to pump gas, with the engine using less fuel volume, the pressure issue shows up again.
1908- sold and missed.
1280- 2.3, FP 35R, E85, etc.
1135- 100% stock
Posts: 2762 | From: Savannah, GA | Member Since: 08/30/05 | IP: (2601:900:8201:62) | Report this post to a Moderator
Generated in 0.346 seconds in which 0.325 seconds were spent on a total of 14 queries. Turbo powered.
