Building long block soon. Hows this look?
cupajoe
Cocoa, FL
Little background: (I'll keep it short) Balance shaft snapped and skipped timing a few months back. And lost all motivation for the car, so parked it in the garage and it sat for a few months. Now I'm about to pull the motor out so I can eliminate the balance shaft and rebuild the head. Then I figured well hell if I'm already going to have the motor out why not build it now so I don't have to pull it again when I max out the stock block? So this is where I'm at.
Budget: $4500
Power goals: 480-500whp reliably.
Rev limit: 7750-8k
Cars use: Daily driver, but may end being a weekend warrior later this year.
HEAD:
-Hot tanked
-Decked
-OEM 6T valves
-BC1100 springs w/ stock retainers
-DKS 272 cams
BLOCK:
-Hot tanked
-Bore and hone .20 over
-Check deck and resurface
-Polish crank?
-Balance rotating assembly
-Wiseco 8.3:1 .20 over pistons
-Eagle rods
-Clevite bearings
-OEM MLS or composite head gasket?
-BSE kit
-OEM oil pump
-OEM gasket/seals throughout
DRIVETRAIN:
-4 bolt rear
-Lighten flywheel ACT?
-Clutch
This part sucks, I just bought a DFCD clutch and only have maybe 2k miles on it. Anyone know if I can just replace the disk with a southbend TZ street disc? Or even a 6 puck?
MISC:
-Evo exhaust manifold
-Cyclone IM
-Might upgrade to V3 link
Now this isn't my only car and might end up just being a weekend warrior. But would like to be able to daily it if I want.
Am I missing anything?
Near Seattle, Washington
Yeah. Missing a lot, actually.
What about the fuel system? Lines, pump, injectors, filter, regulator? What are you going to run to manage it? Do you already have a wideband?
What about intercooling?
What turbo are you going to run that you expect to get reliable 500awhp out of? Wastegate? BOV?
What kind of transmission do you have that is going to take that sort of power/abuse? Hopefully not some 20 year old stocker... same goes for the suspension.
I strongly suggest upgrading to V3 of ecmlink.
JNR
ca
Kind of hard to tell if you're looking strictly for a long block, or the rest of the items that would go with it (i.e. turbo, intake, exhaust, fuel, etc.) to attain your goals?
TomN
North Port, Fl
I would go with 9:1 compression.
cupajoe
Cocoa, FL
Just asking for long block idea's. Check my car profile for mods.
