COVR4355
Active member
Good day my fellow VR4's
Having some issues controlling boost on my newly installed Hallman MBC...I know a few of you are spot on regarding using the 1g bcs with DSMLINK-I will soon.
Nonetheless, the issue is I get upwards to a 10 to 12 lb spike- 10 to 11 lbs at 3200 rpm to 21 to 23 lbs at 6500 rpm with the MBC being hooked up to the pre TB bung-on the TB elbow and the external wastegate.
If I try to hook it up to the bung on the compressor housing it hits like the devil himself, but I cannot get it to drop less then 24 lbs???
Any thoughts?
You guys rock and thank you!
-Joshua-
Any thoughts?
-Joshua-
