WTB: coolant temp sensory pigtail
BadVr4
manchester, ct
i need a coolant temp sensor pigtail that is in good shape. let me know if u have one, shoot me over a pic of it
Wizardawd
Franklin, NC
Well, there are 4 coolant temp sensors.
1 is technically a radiator fan switch and plugs into the radiator under the coolant fan. 1 single wire connector that runs the gauge in the dash, a 2 wire staggered pin connector that is the ECU's coolant signal next to the gauge sender and a side-by-side 2 pin that is used for A/C control at the top thermostat housing.
Wiz
Polish
NE, IN
FYI, standard female spade connectors fit perfect.
Just use an insulated one like in the left of this picture. Fits and works fine, I used them on my car. Cheap and easy way to replace all the failing/corroded OEM connections.
atc250r
Orange County, NY
I'm assuming you mean the two pronged one on the front of the t-stat housing. Just get two female spade terminals and attach them to the stock wires.
John
BadVr4
manchester, ct
can anybody send me some links to where i can buy a couple of those? radio shack only sold the connectors them selves
Wizardawd
Franklin, NC
Spool of wire and some connectors from a parts store...you'll be using it again.
Wiz
spooling92vr4
long island, NY
i dont usually give out my secrets, but the plug is the same as any eclipse/ galant rear factory speaker plug
enjoy
