WTB: compatable injectors for my setup
coyotes
Seattle, WA
Want to run my 2g maf on my stock turbo for now, eventually will step up to a 16g or similar. Id take a 2g maf conversion harness too if anyone has one. I'd be interested in other maf setups as well, evo, 3g etc.
Need injectors that will just swap in. You don't want me changing harness plugs or wiring in resistors, trust me.
Diego
I have some 550s. They would be near stockish with a little more oomph.
Diego
manikbastrd
Quoting coyotes:
There is a member on here that sells 2g maf connectors for like 40$ shipped, although I can't remember who it is.
coyotes
Seattle, WA
I saw that, thanks. If I have no way to tune currently is this sort of setup going to cause a problem? Otherwise I will just wait
manikbastrd
Yes, Your car will most likely freak out and be unhappy with a 2g maf and no tuner, also the injectors will be too large and you will run rich. You can get ECMLink for around 500$, or a Keydiver chip for the injectors and the maf...no idea on cost
If you just swap in some slightly larger injectors you might be able to get away with playing with the MAF screw or otherwise hacking the maf, but this is a ghetto way of doing things IMHO
I was going to post this in the first comment, but then saw you had 600+ posts and didn't want to be condescending
coyotes
Seattle, WA
Naw its OK, I ask stupid questions all the time. I researched this but on tuners people are 50/50 on whether you'd be fine or not.
manikbastrd
link
Specifically,
"Just a couple things to add: You CANNOT run a 2G MAF on a 1G without changing something. Either SAFC, bigger injectors(550-560cc), or a real tune. Because the 2G MAF is able to meter more air, the stock ECU will receive a lower reported airflow and you will run LEAN, not rich. Hence swapping bigger injectors to compensate if you don't use an SAFC/tune...Before you swap MAFs around or start altering your airflow I would highly recommend getting a wideband O2 sensor/gauge and a logger. How much boost are you running?"
Like I said, I wouldn't chance running lean/with a bad tune. It's not worth it and you wont get that much of a gain out of it...On a side note, I have a 2g maf intake tube if you are interested. It is set up for a 1g setup w/ recirc.
coyotes
Seattle, WA
I'm on waste gate pressure with stock turbo. I just want to ditch the stupid 1g air can, its bulk is cramping my style. I will wait until I dsmlink.
That link you provided has so much mixed information.
