Paul (thedsmguy) is out of 5-lug swaps. I'm not sure when he'll get more, so I figure I'll ask the rest of you. 1051 needs five lugs for its new wheels. Lemme know...
I believe the rears are the same and you just swap your abs gear over to the non abs part. There is a 92 fwd turbo car at the yard and I am pretty sure it has abs on it but I'd have to check and see.
Quoting jepherz:
Mark, I have a few sets of rear spindles. If you are interested in just rears from me I can grab you pics this week.
I'd like to buy everything from one person to save shipping costs, but if it comes down to needing just the rear spindles from you, I'll let you know. Thanks /ubbthreads/images/graemlins/smile.gif
BTW, I'd also like to get a DSM ABS control unit if anybody has one laying around. And I need one of those fat washers that go behind the large axle nut on the front axles. Thanks...
Will you be reusing your knuckles and replacing the wheel bearings and seals or are you looking to just bolt on the entire assembly? I can fit these parts in a large flat rate box for $15 if you don't want the knuckles. Not sure what the yard would want for that abs unit but I can ask.
Quoting turbowop:
I have a control unit available. You are talking the computer in the trunk, correct?
Yeah, I've read all the how-to's on retaining ABS with a 5-lug swap on our cars, so I know to keep the front rear tooth counts 1:1. I could use that ABS module if you wanna part with it. PM me plz. /ubbthreads/images/graemlins/smile.gif
