WTB: 1990 non-turbo water pipe
NateCrisman
Blairstown, NJ
Oddball item....but Im looking for a 1990 NON TURBO water pipe....without the nipple by the water pump for the sandwich oil cooler....AND without the threaded boss for the water feed to the turbo.
My GVR4 came with a dry bearing housing on the turbo (no water lines) and 1990 OFH. AND previous owner lived in florida and did a "heater core delete"...cutting off the branch of the water pipe that feed the heater core and throttle body. Car moved to New Jersey.....Im freezing my butt off!
maroonmetallic
central WI
Aren't all non turbo 90-93 water pipes the same??
I have at least one sitting around.
-Shawn
NateCrisman
Blairstown, NJ
Quoting maroonmetallic:
-Shawn
you know, they probably are....Iv not really done much with non-turbo engines at all...not sure if the 91-94 non turbo 2.0L had the coolant filled sandwich style oil cooler or not....but I was pretty sure 1990's certainly wouldn't have...hence why I asked for 90.
strokin4dr
Savannah, GA
'90 T/E/L turbo - coolant line to turbo (air/oil cooler)
'91-'94 T/E/L turbo & '91/'92 GVR4 - coolant line to turbo and to oil cooler
'90-'94 T/E/L N/T - no coolant lines
NateCrisman
Blairstown, NJ
ok then....I need 1990 non turbo. no coolant nipple on the pump end. no threaded boss for the turbo.
maroonmetallic
central WI
I had a few dohc n/t galant, and have never seen a cooler on a n/t 1g DSM in the local junkyards.
I have one from my 92 GSR if you're still looking.
89Mirageman
Stantonsburg, NC
Same thing I was thinking, pretty sure all nt 1g dohc 4g63 water pipes are the same.
thomcasey
Indianapolis, IN
Yea, they are. The "cooler" was used to supersede the Air oil cooler. They were on turbo models only.
strokin4dr
Savannah, GA
Thanks. I updated my post above. Good to know.
NateCrisman
Blairstown, NJ
Ok now that we have this covered! /ubbthreads/images/graemlins/dunno.gif
Anyone have one kicking around ready to ship to me?
862 251 2571 TXT [email protected] for email
At this rate Ill get the heat fixed just in time to start bitching about A/C issues. /ubbthreads/images/graemlins/rofl.gif
89Patches
Ontario Canada
There was a guy here in Ontario that had a box full of NT Water pipes all brand new. I'll shoot him a message to see if he still has them.
89Mirageman
Stantonsburg, NC
Quoting NateCrisman:
Maroonmetallic said he had one.
