Which 90A alternators will fit these cars?
I will be headed to the boneyard soon. The boneyard is huge, however I am not counting on seeing any GVR4's.
I would like to be sure that I am not downgrading to a 75A alternator when I pull from a Galant with a different trim. It seems to me that all I have to do for the other trims is make sure that the car is an auto.
Is it that simple? /ubbthreads/images/graemlins/dunno.gif Does anyone have any idea?
Thanks!
I dont know what models have 90A stock, but doesn't the alternator indicate how many amps it puts out somewhere on it? I know they do when you get a new one with a sticker..... i think its engraved on there somewhere too.
IncorpoRatedX
Arizona
Rock auto says:
DODGE 2000 GTX 1989
EAGLE 2000 GTX (1991 - 1993)
EAGLE 2000 GTX 4X4 1992
EAGLE TALON (1990 - 1991)
EAGLE TALON TSI (1990 - 1991)
MITSUBISHI GALANT (1991 - 1992)
MITSUBISHI GALANT ES 1993
MITSUBISHI GALANT GS (1991 - 1992)
MITSUBISHI GALANT GSR (1991 - 1992)
MITSUBISHI GALANT GSX (1991 - 1992)
MITSUBISHI GALANT LS (1991 - 1993)
MITSUBISHI GALANT S 1993
MITSUBISHI GALANT VR-4 (1991 - 1992)
PLYMOUTH LASER RS (1990 - 1994)
i dont remember the 90A every being in lasers or talons.
Also, I was reading...(maybe on RockAuto or Autozone's website) that the alternators are 75A for the manual non GVR4's.
raptorWagon
Oak Harbor, WA
Quoting Alpha Male:
Rock auto says:
DODGE 2000 GTX 1989
I dont remember the 90A every being in lasers or talons.
CAPs says the same thing, but in detail it is broken down by drivetrain, motor, etc. 2G NA Spyders have 90Amps as well.
Is it internal? That would be a good idea. I got a canadian alternator off of ebay though so hopefully I am set.
Thanks, I read something about 2G alternators having different connectors though.
Quoting raptorreed:
Quoting Alpha Male:
Rock auto says:
DODGE 2000 GTX 1989
Don't believe this. The 75A alternators will work on any 1g dsm & gvr4 as will the 90A. Hence they list them as being able to work on all these cars. If I recall correctly, only the gvr4 came with the 90A unit.
IncorpoRatedX
Arizona
ive used the 75 amp one without any problems.
G
zompton
I have a 140amp bosch & 90amp bosch fs if anyone wants them.
misterfixit
Midlands, UK
The 90A if you look in through the holes on the back where the heatsinks are has 4 pairs of diodes. The 75A has three pairs. otherwise they look exactly the same from the outside. look for a twincam auto. they should have them stock..
Rich
fivestardsm
Middle, Michigan
I see you pretty much have this cleared up, but I figured I would put in my $.02.
I found that the Auto AWD E, T, &L all had the 90amp. The reason that I found for this was because of the extra power draw for the tcu and electronics in the transmission. When I bought my first alt from autozone, I bought it for a 91 Auto AWD Talon just so I could have the 90 amp.
Good info, but check this out....
Autozone lists the auto as having a 75A alternator. I still can't find the 90A locally
and I am ready to give up and just put the 75A in. I don't want to have to wait for them to order a new alternator every time one blows if you know what I mean. They will get lazy and they will end up not swapping alternators under their lifetime policy.
Any ideas?
Thanks
fivestardsm
Middle, Michigan
Yeah, They changed it because of the "dura-blast" swap out. Before they had all that, they had a different system which allowed them to source their parts from other reman suppliers. Duralast is all their "own" name brand, but buy their parts from certain reputiable suppliers, which package it in the duralast box.
When I first bought my alternator, it was before the duralast deal, they actually carried both the 75 and the 90 amp on the shelf.
