I'm trying to figure out where I can get a -3an oil feed line if I decide to run the hx35. Either that or I can run a -4an SS line with a .075-.090" restrictor but I can't seem to fine either. If you know where I can find either let me know, Thanks.
I just bought one of these yesterday for my holset install, Its only a .04" restrictor hole but just use a drill bit and make it whatever size you want.
I'll check that out, I might have to call them as I don't see it listed. I would get that .40" oil restrictor but I'm a little unsure of how the measurement goes, so if you could clear that up for me that would be great. I need .75-.100" restrictor so is .40" more or less then .75" So .40" lets more oil in and .75" is less oil? Guess I'm just lost.
The other way around, .040 would let less oil in than .075 would. basically what I plan on doing when I receive my restrictor is to take a 5/64 drill bit and make the hole bigger. 5/64 is .078 in size, So it should be good to go.
