My car will not start. I have DSMlink what should I be look at to solve the problem? It turns over fine but will not start and every once and a while to back fires. I have zero CE codes.
I agree with EMX also try this link if you can't get help on the forum right away click Good luck and Merry Christmas now get the VR-4 running. /ubbthreads/images/graemlins/grin.gif
Quoting EMX5636:
Not saying there isn't anyone who knows Link on here... But why don't you try the DSMLink forum? You may get quicker setup replies. Just a shot.
I might do that but the reason I tried here is because there are a bunch of people on here that I respect and have been into these cars for a very long time. There is next to nothing that the members on here don't know. /ubbthreads/images/graemlins/cool.gif
Check the timing like suggested, the backfire and no start are classic symptoms.
If good check the coil items ( igniter and coils ) then the CAS.
Last have you had your ECU capacitors checked/redone?
