So I found this problem the other day when I raised the car up with jack to change the bad slave cylinder (which still hasn't been fixed /ubbthreads/images/graemlins/banghead.gif). This was the first time I had jacked up the car and the problem wasn't there before. I don't know what type of diff it is or whether it is 22 or 23 spline but I'm sure you guys could tell just by looking at it or even better yet, I go out and record whatever is written on it and tell you and you tell me what type of case it is. Anyways, this problem only happened when the front end of the car was up in the air, so is the problem just because the whole thing tipped back caused the fluid to leak out? I couldn't quite tell where it was leaking from either? That kind of makes sense to me, but I don't want it to leak at all. I believe it has stopped leaking since.
click me
click me
