tranny drain bolt thread size
Should be 18mm X 1.5, IIRC. Easy way to check is if an old O2 sensor will screw in, all O2's are the above thread.
4doorboost
Westlake Village, Cali
so the reason i asked is cause the threads in my tranny stripped should i helicoil it and use the same bolt or tap and go one size bigger? thinkin just helicoil so i can use the same bolt
