Stalling when engine-braking to a stop (RESOLVED)
EfiniX
portland, or
Yeah, it coasts just fine. I"ve never had it stall while rolling on open road. Only when coming to a stop, when it is below 10mph for sure.
AllanL
NV
not the dreaded idle stall?
not this? click
i do not have such on my car, so i just increasesd the zero/low load timing areas of the timing map.
EfiniX
portland, or
Might be. My idle air clamp is enabled, but the values are higher then the recommended values on the ECM website. I'll make some tweaks and report back.
EHmotorsports
Beaverton
only thing that hasn't been done is the Fiav. we can block it off and check it again.
I'd try that too. That could be why it's worse when the engine is hot.
MellowVR4
Milwaukee, Wi
What maf are you using?
LIV4PSI
O-H-I-O
Quoting EfiniX:
Quoting EHmotorsports:
I am starting to wonder if the resistance in the harness is increasing just enough to cause this after long hot droves.
Well it is certainly more pronounced when I've been driving for a while. Just fine when for short drives.
Interesting theory...
The ECU makes the engine idle much higher during cold idle to help get it warm. I bet that is why it is worse during long drives.
My Subaru has this problem, unfortunately I just learned to live with it
lancerglx
Member
malta
would it remedy the problem if a fiav/isc blockoff plate was used since you can keep the engine at a sightly higher rpm when idle without it going too high high when its cold.I have the same problem but its fine when cold hence the revs are slightly higher,,then when the revs drop and its at normal running temp it will stall when shifted into neutral.
mitsuturbo
Near Seattle, Washington
Quoting EfiniX:
New PVC valve.
This is all so strange...
A PVC valve? That is strange indeed. You may want to install a PCV valve instead. PolyVinylChloride and 4g63's don't go well together. Positive Crankcase Ventilation valves are somewhat beneficial, however.
Quoting MellowVR4:
This was asked previously. OP didn't answer.
EfiniX
portland, or
MAF is stock, I think. ECMLink is configured with a Base MAF Type of "2G MAF".
Here's a picture if it helps?
coyotes
Seattle, WA
That is definitely not a stock MAF. Engine bay looks real nice dude. /ubbthreads/images/graemlins/applause.gif
MellowVR4
Milwaukee, Wi
RECIRCULATE the BOV.
He has another thread discussing his issues with his recirc, and the resolution for it. It's set-up right.
Not a stock GVR4 MAF, but a 2G. Pull it off and check for the honey combs, no combs makes for much needed MAF comp.
EfiniX
portland, or
I've actually done a good bit of work on the MAFComp already and it's operating right where I'd like it to at normal RPM's. I'll pay more attention to it at idle.
I'll have an update tonight for sure. I've got an hour drive after I finish work today, and I'm sure it will present me with a stall opportunity. Even if it doesn't die, I can see if the dip has improved with my clamp adjustments.
mitsuturbo
Quoting prove_it:
VTA with a draw thru maf is not "set up right" regardless of any electronic compensation. /ubbthreads/images/graemlins/banghead.gif
BTW, what is the Coasting FC offset set at?
I don't get where you think it's VTA. Pic from his BOV flutter thread:
Quoting EfiniX:
What's your idle air per rev? Are you close to the .25 mark?
mitsuturbo
Aha. Of course that's the first thing we all suspect when someone claims their car is dying on decel. I didnt see any mention as to it having been recirculated.
Still, i wonder though. What is the Coasting FC offset at? I had to raise mine a bit, although i have a far different setup than this.
EfiniX
portland, or
Idle at 950 w/ FC offset @60. AirflowPerRev @ idle is stable around .25, so that's looking ok.
I've got my fingers crossed that the clamp works out.
Me too. Are you using the factory o2 sensor location, or do you have a WB simulating NB downstream? I know I have my WB downstream simulating NB and there is a latency there for the ecu to adjust trims.
