Ryan's #303/2000
Orlando, FL
Chassis:
91 GVR4 #303/2k
Mazworx 6 point roll Bar
ABS Delete
PS Delete
4WS Delete
4 bolt rear
5 lug conversion
Harnesses Driver & Passenger
BBS 16 x 8 wheels
Mickey Thompson 255/50/16
ARP Wheel Studs
1G Big Brakes
Engine:
Stock Bore 6 bolt block
Checked Uncut Crankshaft
ARP Main Studs
ARP Rod Bolts
ARP Head Studs
ACL/Clevite Bearings
Eagle H-Bream Rods
Wiseco 9:1 Pistons
1G Head Stock
3g Lifters
Crower 414 Cams
Adjustable Cam Gears
OEM Mitsu Oil Pump & Cover
OEM Water Pump
Fluidampr Harmonic Balancer
Saturn Alternator
Jay Racing Alternator Relocation Kit
Hot Side:
DNP Exhaust Manifold
FP 3575
3" SS FP o2 Housing (V-band)
3" Buschur (I think) Downpipe (V-band)
3.5" Custom Exhaust to 3.5" Muffler
Cold Side:
2.5" Lower I/C Piping
3" Upper I/C Piping
Unknown FMIC (pretty big)
HKS SSQV BOV
1G Magnus SMIM (newer version) w/75mm flange & Nitrous Bungs
Stock 5.0 63ish?mm Throttle Body
Cooling Mist Meth System
Heat Barrier Intake Gasket
Fuel & Other:
Walbro 255 HP In tank Fuel Pump
Stock lines up to filter
FIC 950cc Injectors
Aeromotive Adjustable FPR
AEM EMS w/GM IAT & GM MAP Sensors
Innovate LC-1 Wideband Kit w/XD-16 Gauge
Boost Gauge
EGT Gauge
Oil Pressure Gauge
Prothane Motor Mounts
Transmission:
1G Automatic Conversion (w/tcase & rear)
TCUGO w/Digital Readout Controller
IPT Restalled Stock Converter
New end clutch
Shift Kit
Trans Cooler
On the Way
-JMF oil catch can
-Magnus Fuel Rail
-FIC Bluemaxx 1650CC Injectors
-2x Bosch 044 Fuel Pumps
-Perma-Cool Fingerchopper electric Fan (2950CFM)
-TIAL Q BOV
Wilson 75mm Throttle Body
Custom FMIC
Orlando, FL
That's actually after my brother cleaned it up a bit and moved everything either down or off of the firewall. The wiring is still very messy. Everything should be cleaned up soon.
Waiting for the Wilson 75mm throttle body to come in to do the custom FMIC
awesome shots, and awesome car.
Those wheels have changed my mind about doing the 5lug swap. great choice wheels.
Junior392
Saratoga County, New York
Wondering what kind of radiator you have. Also the installiation of it? I am looking for a half size radiator myself and am interested knowing about your setup.
Thanks in Advance
Orlando, FL
The radiator is from a 92-00 SOHC honda civic. Mine was an aftermarket one bought on ebay if I remember correctly. When Deanan installed it, looks like he used the stock brackets and trimmed the stock hoses. The car usually runs around 210 when driving in the city. That was when i was having problems burning out electric fans and with no tune on the car. I just ordered another 3000 CFM, finger chopper from perma-cool and going to see if that helps at all. There are a few different write ups on DSM Talk, DSM tuners, etc. We did the same install on my brothers 95 GST and it runs fine with no overheating issues.
Ralli380Gvr4
BOULDERADO/UWS-NYC/BURQUE
McLovin' the BBS', Classic look and stance. The classic mesh look is uncommon w/ USDM vr4's, but you nailed it(or your brother did /ubbthreads/images/graemlins/smirk.gif ) either way, this thing has class and style. Very engine bay.
Some new additions:
Garret 4.5" core and custom FMIC kit. Built by Mike Vig at RealStreetPerformance here in Orlando. He is also a fabricator at Titan Motorsports.
In these pics...
Tial "Q" BOV
Wilson 75mm Mustang T/B
Jackson auto Machine throttle wheel
Phenolic t/b gasket (bought on the dsmlink forums)
FFWD "bee-mad" beehive springs, Ti retainers, nitrated seats and Manly machined/nitrated locks, "low rider" VSS's
FP inline filter and custom feed line (note: it no longer has the incline as pictured)
Heatsheild Products T3 turbo blanket
BFG KDW-TT street tires
JDM corner lenses
Next:
FIC 2150's
x2 Bosch 044's
fuel cell
wire tuck and custom harness
powder coating the charge pipes, valve cover and catch can
Garrett intercooler core (for reference)
I think the core itself is 24"x 12"x 4.5"
Whoodoo
Binghamton, NY
Holy intercooler core Batman! Looks really good man. That fab work looks top notch, its good to see solid work going into these. None of that 'we do it nice cuz we do it twice' junk. Good choice of beer too /ubbthreads/images/graemlins/smile.gif
How much of the bumper support is still there? I've been thinking through an intercooler setup and the way I want to do it will require a fatty core like yours, but I really don't want my bumper to sag at all.
Just plain sick looking car when are you heading to the track to see how fast it goes.
Thanks for the compliments guys! Mike Vig does phenomenal work. He has worked on some of the worlds fastest cars, including Darrin Dichiara's 8second 6spd Supra. (http://www.youtube.com/watch?v=VLHbXGM1lIQ)
Most of the bumper support is gone at this point. There are only two posts that connect the fascia to the car. The need to fabricate a better bumper support is evident. Though, the sides are sagging on this car because they have broken bolt holes where the fascia attaches to the fenders.
vr4beast,
The car actually belongs to my brother. I drive it on occasion and do most of the work while he is in Iraq. I could take it to the track and get a baseline, but I believe all of the cars achievements should be had while my brother is behind the wheel. So to answer your question - As soon as my little brother is back in the country. /ubbthreads/images/graemlins/smile.gif
I hope to have the fuel system done, and the car fine tuned by that time.
Orlando, FL
Have been away from the forums for a while but still around and getting back into it again. I still have the VR-4, between being deployed and serving two back-to-back 3 year overseas assignments I haven't quite spent as much time on the Galant that it needs. The AEM EMS recently took a crap and is in the process of being replaced with an Infinity 6. Car will also be getting a wire tuck, planning to go with wire-worx to sort out the rat's nest under the hood and tuned by RealStreetPerfomance. The FP3575 has been rebuilt, new Scirocco Radiator, and intercooler pipes powder coated wrinkle black.
Most recent pic
Installing Bulfab's GVR-4 3-PIECE CROSSMEMBER - Steve (DamnDSM) cleaned up the welds and had it powdercoated.
Discovered that the car has a mix between auto and manual engine brackets so having trouble getting it lined up. Fortunately Steve went to MTI for welding and has access to equipment at work.
-10 feed lines to fuel rail, -6 return
Don't have any pics but installed a 15gal Fuel Cell, dual Bosch 044's, and have 2150cc injectors ready to drop in
