Replacing Left Rear axle (3 bolt LSD)
I have a replacement left rear axle. Any idea how to replace it? Can I just remove the 3 bolts to the cup and pull the axle down or is it more involved?
I don't want to waste time removing parts that aren't necessary, but it doesn't seem like there is much info available so I may have no choice.
Can you help me?
Thanks
kama1
q.c. philippines
Iirc just take the bolts out .
You'll need the left rear wheel off the ground. Remove the three bolts from the cup, and the axle will then drop down far enough to clear. Put pan under the diff to catch any fluid that may leak out. Pop the axle from the differential using a pry bar (carefully) and your done. I would replace the seal on the differential too as it may not seal perfect to a new axle. Super easy to do. Just be sure to add a little grease to the seal surface so it doesn't tear, either new or old seal.
That's all, it's a pretty easy job to do. Right side is the same way also.
Thanks...wasn't prepared to need a new seal though. /ubbthreads/images/graemlins/frown.gif
What do you think the odds of it not sealing are? Also, how much diff fluid will I lose? I have heavyweight shockproof in there. I am a cheap bastard and don't want to add any. I know that the shockproof will leak slow but in addition to being cheap...getting some more locally may not be easy at all.
Your ok to skip the seal, just keep an eye on the diff over the next few weeks, if it does leak you already know what to do. As for the fluid draining while replacing the axle, if you jack up the left side high enough so the fluid runs to the other side i doubt you'll lose much if any. I'd put the pan down just in case. Have the axle ready to in and do the swap quick, you should be fine.
Came out so easy it wasn't even funny.
However, I am definitely struggling to get it back in. Am I supposed to beat it back in?
Thanks
LOL, that needs to go into the sexual overtones page.
Anyway, no you shouldn't have to beat it in. You do need to give it a firm push though because of the circlip on the end. Try pulling it out and turning it and retrying to insert it. Be careful not to damage the seal.
Gotta push extra hard on it...hard to do with a borked collar bone. /ubbthreads/images/graemlins/smile.gif
Just slide that shaft in gently and give it a nice firm push until it's all the way in. You may need to wiggle it a little to get it in.
Yep I said it.
Had to do it.
AWDPower
Vacaville, CA
I forget, but I think the tri pod joint that moves in and out it is the inner joint on a three bolt axle. If so, you can use the axle itself like a slide hammer. Insert the splines into the diff, then pull back on the axle a bit to extend the inner joint. Then push it back together quickly, and the end of the tripod joint will hammer the cup into the diff. Repeat until seated.
Quoting prove_it:
Lol that's what she said. /ubbthreads/images/graemlins/grin.gif
