Removing AWS rack from rear subframe
Romanova
Cypress, TX
Jesus, WTF am I doing wrong? The bolt just spins and spins. I put a wrench on the other side and it won't budge... not even with the impact wrench. Tips?
In that photo, the piece on the right?
That may have two nuts, one on the top and one on the bottom so you need to find a slim wrench to hold one while you unscrew the other nut. /ubbthreads/images/graemlins/dunno.gif
If it won't budge then soak it with pb blaster or wd40 for a while.
Romanova
Cypress, TX
I was using a slim wrench to hold the top side while working the bottom with the impact. Soaking it more with PB to see if that will work.
Muskrat
Lexington, KY
Get a friend to hold the wrench and use a big breaker bar to crack it loose.
Romanova
Cypress, TX
The problem is the wrench keeps slipping off when I put pressure on the other side with the breaker bar. About to use the SawZall to cut the rack off and leave the ends on the subframe... ugh.
Jostar
Chicago,il
I knocked mine real quick, cut the sonnavabich if it won"t budge...
Olson
Moreno Valley CA
Heat it up with map gas then take it off
Quoting Romanova:
Maybe you can put the wrench on the nut and then spin the bottom nut until the wrench on the top nut catches something and stops. Or maybe zip tie the wrench to the arm to keep it in place while you wrench on the bottom nut.
GVR-4
Asheville, NC USA
Isn't one of the tire rod ends a left-handed thread?
