Rear Diff Grinding/Diff fluid recomendations
Number996
Gaithersburg, MD
Hey Guys!
We to drive to work this morning and seems a muffled grinding has developped. It's coming from the rear of the car and only makes noise when i downshift a decelerate in gear. Soon as i touch the gas or push the clutch in the car rolls with no noise. So i think it's my rear differential.
I haven't swapped diff fluid since i've had the car because other parts and work have taken priority. I believe it's still a 4 bolt diff.
What gear fluid do you guys use??
Shockproof heavyweight.
I warn you though, fluid may not fix it, as it sounds like the bearings are out and it needs a rebuild. A fluid change may quiet it down, but it's not a fix.
CutlassJim
Manchester, NH
Yup your rear end is getting tired. It's either a bearing going out or the shims getting weak giving you excessive lash on decel. Rebuild time.
Wizardawd
Franklin, NC
Agreed, #17 did that the day we picked it up. 250k miles on it took it's toll. I ended up swapping to a 4bolt LSD instead of rebuilding the stock rear.
Wiz
Heavyweight Shockproof...problem seemed to have started when I put the shockproof in...never noticed it prior....unless someone masked the sound by using another fluid prior to that. /ubbthreads/images/graemlins/dunno.gif
Probably, shockproof has been proven for years now in thousands of DSM's.
That was the theory someone else had too. Guess I'll drive it until it grenades.
EfiniX
portland, or
I'll support this as well. Shockproof heavy in the transfer and diff. Diaqueen in the tranny.
