Power steering pressure hose seals?
theevozero
Odessa, Texas
Has anyone found them locally? I can find pump seal kits online all day, but I just need the 2 o-rings that fit on the pressure hose shaft on the pump. Attempted to use 2 generic o-rings from a large kit, but once the car started, they started leaking again.
theevozero
Odessa, Texas
I gave up and order the whole seal kit from the dealer. Problem solved. $20 can't beat that for oem parts.
ktmrider
Tempe, AZ
In a pinch ( out of town once and on a weekend another ) I used two small(er) o-rings stretched tightly. There is very little clearance between the banjo bolt and PS hose end.
BTW both times it worked great, no leaks.
theevozero
Odessa, Texas
I may do that tonight, so I can run the car. I really don't wanna drown my alternator in ps fluid. Thank you.
theevozero
Odessa, Texas
Not yet. I will on Monday.
I have this....
Wizardawd
Franklin, NC
Local parts stores usually have a nice bin selection of O-rings. Usually around $.40 or so each. Where I have always gotten mine from and no probs. Screw $20 for 2 O-rings.
Wiz
theevozero
Odessa, Texas
It's $20 for all the o-rings. I'm gonna reseal the whole thing and not worry about the pump frying my alternator anymore.
