palm pocket logger...temp 260-270 normal?
desant78
Clarksboro, NJ
Hello GVR4.org
my wiring harness was hacked real bad..and I'm finally at the stage of fixing the thermostat and temp readings. Replaced temp sensor and same readings.
here is my issue.....cold the temp is real low..don't remember off hand sorry /ubbthreads/images/graemlins/frown.gif but warm it is around 260-270...and the dash is 1/4 warm the temp guage.
is this normal? perhaps my palm is not reading super accurate? what kind of temperatures do you guys get with your loggers?
thanks in advance!
Jesh
Soldotna, Alaska
I don't have a logger but my mechanical temp gauge reads about 180-200F depending on the day. 200-220F if I'm giving the car a good workout, Anything above 220F and I start to worry.
Chicago1
rio rancho nm
Wow that's running hot. Mine never gets over 220 even driving hard. Are fans coming on? How's your thermostat? Any debris blocking airflow to the radiator?
toybreaker
iconoclast
You might want to check the wires at the t-stat housing to make sure they go to the right places
... I remember posting in a thread about this awhile back ...
[edit] found the threads
Quoting toybreaker:
Quoting desant78:
When i bought 1662, the PO cut all the factory plugs. Does it matter if you switch the yellow wires shown? I might have accidentally done that and that would be causing all my problems of reading 7 to 15degF temps..
For a quick test to sort this out, with the key in the on/run position, take the single wire that runs out to the t-stat and jumper it to ground briefly while someone watches the temp gauge.
If that is indeed the wire that runs to the gauge, it'll peg the temp gauge on hot.
A few seconds won't hurt anything, but don't leave the wire grounded for long, as it will eventually piss off the resistors that make up the wheatsone bridge inside the gauge, and that will affect it's accuracy.
If that wire really belongs in the two pin set that runs out to the ecu, the temp gauge won't move.
... and have made other posts on this as well, including this one;
Quoting toybreaker:
An easy way to check for crossed green/yellow wires at the temp senders is to ohm out the wires.
The yellow/green wire at the two pin connector in the engine compartment runs out to the ecu at terminal #20.
The green with black wire from the two pin connector goes over to the ecu at ecu terminal #24
The other yellow/green wire from the single pin connector only goes to the gauge in the instrument panel.
Have you verified the wiring is correct?
Jesh
Soldotna, Alaska
Have you changed the length of the wires going to the temp sensor? This will affect tempature readings as well.
mitsuturbo
Near Seattle, Washington
I believe there is a well known and documented issue with the temp readings on some PalmOS based logging software. Google may be something you want to turn to for this issue. If a search yields some results, you have your answer. Otherwise, please continue to post here describing your scenario. Temps that high pretty much guarantee you're going to "boil over" regardless of what mixture of coolant/water you're running.
desant78
Clarksboro, NJ
hey everybody the help has been great....
toybreaker - i started trying to resolve this issue between finals week in school and I think i lost track of what I tried to do/any advice. that being said thank you (for the help again) and I will check back with your resutlts.
i have ran my car for about 20 min at a time at the so called "260" and the engine starts n runs normal so i am assuming it is wrong...thank you everyone for the help I will report back with any progess
desant78
Clarksboro, NJ
Thanks Toybreaker!
Along with Toybreakers comments and the ecu pin out I found I was apparently never grounded /ubbthreads/images/graemlins/banghead.gif there are two "black and green" wires, but only one of them was a ground I needed.
Thank you everyone for the help...now onto the next issue.. /ubbthreads/images/graemlins/smile.gif....I am currently researching the form for possible solutions as to not flood gvr4.org with problems without trying to be proactive in finding my own solutions
once again everyone thanks for the help and patience!
