Hi
1994 F4A22 KM175 transmission no reverse or overdrive
Transmission runs perfect in all gears 1-3....When in park first gear is still engaged and wants to move forward if accelerated and when in reverse first gear is still engaged and will not go into reverse....i guess because first it is still engaged.....Also when in reverse seems like the parking pawl is still engaged
When in neutral the car is in first gear and will go up to a certain MPH then it will seem like neutral till speed comes down
When overdrive button is pressed car slows considerable and will overheat transmission due to i guess first gear not disengaging...
None of these symptoms exist when the vehicle is off wheels move freely in all gears except of course park.......Also this occurred once before and went away but now two weeks later it is back and seems to be here to stay....Any help with a diagnosis would be greatly appreciated!
Linkages are ok as well as fluid...changed fluid no metal parts ect.
Thanks
Thanks
