New rim option.
boostx
Orlando, FL
What you think ?.
It was a direct bolt on. Car already been swap to 5 lug.
citymunky
Chesapeake, VA
IMO, not bad but not nice. The design of the rim doesn't fit the box body of the galant.
PreskitVR4
Prescott, Northern AZ
Looks good, prob not so safe though. Audi is 5-112, where as our 5 lug is 5-114.3, audi also uses a lug stud with a ball seat, as opposed to most lug nuts that are a 60 degree acorn seat. So, as there is only a 2.3 mm diff in the bolt circle, it appears to be "direct bolt" when it is not. I'm not trying to be jerk, just have tons of experience in this area, want you to know the facts.
bobdole
U.K.
Quoting PreskitVR4:
I would also add how dangerous this is. I have seen wheels fall off MB and Audi because the wrong seat of lug nut was used. If you are using cone seat lug nuts with these wheels take them off asap. Also the reason then went over the 5.114 bolt pattern is because Audi use a 14 1.5 stud.
fuel
Toronto, ON, Canada
not to mention those wheel studs/lugs are probably bent now.
thedsmguy
Vancouver Washington
I've seen lug nuts that "swivel" on the top to allow for up to 3mm difference in PCD. I'm to lazy to search for them again but they are out there, they basically have a washer that is concentric (???) and a cone shape to seat to the wheel. All the reviews say they work perfectly.
Good luck. I sorta like them but not all that safe...
fuel
Toronto, ON, Canada
yeah we call them wobble nuts.
