Modernizing my car
Last weekend I put a keyless entry on the 92 GVR4. I feel so up to date! /ubbthreads/images/graemlins/wink.gif
Also helped solve my problem of the alarm activating every time I unlocked the car from the driver key cylinder.
I bought a Commando one for $39.95, and didn't install any of the fancy stuff, just the straight up keyless. Hardest part was accessing the ETACS (way up in the left corner of the instrument panel, above the fuse block/junction block).
Nice small fob, and really is nice. Bought this
That is all.
fuel
Toronto, ON, Canada
^^ shouldn't have to? Don't the USDM models have a button above the power window control on the handle that locks/unlocks all the doors like the JDM models do?
SleepinGVR4
Danville, Pennsylvania
Fuel,
No they don't. Although if you pull up or push down the door lock "tab" it will lock all the doors or unlock all the doors. This works for the driver and passenger side doors.
This mod interests me.
Diego
^ mine stopped doing that randomly.... I need to check why.
OMFGeofffff
Burnsville, MN
Quoting SleepinGVR4:
So you didn't have to install some type of popper in the door?
This isn't what you think it is. Its basically a keyfob that locks/unlocks your doors instead of having to stick the key in the door.
Brunoboy
San Bruno,CA Home of SFO
I have had a two way pager alarm and remote start in my car for the past year. I disabled the old alarm by snipping a Yellow/Blue? Wire under the dash that I saw the HOW TO on this board. The aftermarket alarm is based using the door trigger wire under the dash near the fuse box. I have the Whole Wiring Schematic for our car and which wire to splice into, where its at, and what color they are if anyone is interested.
-Shane
EgonOlsen
Denmark, Europe.
I actually bought a similar setup with flip keys that I havent installed yet.
So info on what wires to solder it to would be nice if you have it?
matt92vr4
Venice, FL
That's cool. I have the same problem with unlocking the car from the drivers door. I'll have to put this on the to-do list.
As mentioned, no need to add anything since they are power locks with actuators already. All you are doing is triggering the actuators.
I installed the new transmitter box, connect up two wires (one for lock, one for unlock) to the ETACS, and three power circuit wires: One 12V battery source (acquired at ignition sw), one 12V switched source (also from ignition sw), and a ground wire. Because I didn't want any of the parking light flash, horn sound, dome light feature, or alarm, I used very little of the supplied wiring.
You can get the wiring diagram colors for your specific year (if you don't have a service manual) here:
galant diagrams
strokin4dr
Savannah, GA
I have the Commando 2-way paging system in my car and love it. Its been installed for about 4 years now and still works great. Lots of features that you can set up too like a turbo timer and remote start. I recommend it because of the good price.
