just bought gvr4 PlEASE help not boosting and cant idle
yeti
san diego california
just wondering if any thing does not look normal
and is there supposed to be 4 ports a1 a e p
0r just a e p
AND IN SECOND POST, SECOND PIC, IS THAT THE EGR VALVE
i just dont know what these are since there all just laying around
yeti
u have none of them hooked up
did u run lines like the taboo speed shop says?
i dont have a cat so im not worried abut smog should i try and run lines like one of the taboo speed shops diagrams
Adorsey
mass
Yeti has a vacuum bracket still hooked up. its stock material. Yeti- your posts would be easier to understand if you through in some punctuation. sh*t makes my eyes cross.
Egr valve, second picture, yes. That must have a Vacuum line off of it. Find it on the diagram and make sure it goes to the correct spot.
check for cracks or leaks.
Same with all the other lines.
Have you made a vacuum tester yet?
Hook up your boost gauge, and make a vacuum tester.
You system should hold at least 10psi for a decent time before dwindeling away.
Adorsey
mass
Quoting 496of2000:
I've been having my fair share of problems too. Found a boost leak, it's crack. This explains my maxed out low fuel trims.
I could hearing hissing sound while it was idling. Located on the intake mainfold, between the TI.
Replace it. /ubbthreads/images/graemlins/dunno.gif
yeti
Got pieces for boost leak test I am just to retarded.
Also sorry about punctuation never was good at it. but definitely will try and apply more + I am either on my phone or using the onscreen keyboard since my sh*t is broke
AND is this the EVAP. can?
ALSO whats the firing order so can check if the plug wires are connected wrong or would the car not run?
