injector resistor pack wiring
yeah iv been doing a turbo conversion on my galant gsx and havent really found any good info on how to wire the resistor pack, if some one could explain it for me that would be great thanks
Its really rather simple:
1) there is a COMMON end of the resistor pack, where all 4 of the resistors are tied together. That needs to connect to the heavy black/white striped wire under the hood that powers the transistor and coilpack for +12 volt power.
2) the other end of each resistor connects to the positive end of each injector, and the ECU drives the other end to ground to fire the injector (polarity doesn't matter).
as keydiver stated... one is a 12 volt switched power and the other four get wired to one side of the injector clip (doesn't matter which of the two wires gets the 12 volt. the other side of the injector clip gets ground signal from ecu (this has to be on point, make sure the correct wire gets connected to the correct injector).
resistor pack colors ( if you have a connecting pigtail)
red = 12volt ign source if not a mpi main relay (if just giving it a ign source i would still use a relay).
black/yellow = injector 1
black/blue = injector 2
black/white = injector 3
black/red = injector 4
if you don't have a connecting pigtail
the only white wire on the resistor pack give that the 12volt switched i mentioned above
the other four black wires just connect one to each injector.
ecu injector pins and colors
pin 51 = injector 1 ground yellow/blue
pin 52 = injector 2 ground yellow/black
pin 60 = injector 3 ground light green
pin 61 = injector 4 ground light green/white
