Fuel upgrade
marvinmadman
Lafayette, Louisiana
I want to upgrade my whole setup. I want Russell classic hoses and plan on modifying my stock fuel hat to -8AN. What is the best way to accomplish this? Buy a complete kit or piece it together?
LIV4PSI
O-H-I-O
Piece it together, and have the bulkhead welded onto your sending unit.
I have -8an/-6an lines, afpr, and a FIC rail for sale.
marvinmadman
I already have an AFPR kit. I want the black nylon lines. Which fitting is available to weld up? I looked a little and didn't see what I needed.
LIV4PSI
O-H-I-O
You should be able to weld on any bulkhead. You don't have to, but they seal better that way
LIV4PSI
O-H-I-O
Here is pic from my STi. It's not welded and you can see how easy the crush washers get deformed
LIV4PSI
O-H-I-O
My trunk always smelled like gas from it not ever sealing properly. Maybe I just over torqued it.
EHmotorsports
Beaverton
They do make steel AN's that you can weld.
marvinmadman
I know. I just couldn't find one with a barb on the other end. I don't want to weld on both sides of the hat. Any links to some fittings would be appreciated
LIV4PSI
O-H-I-O
That was one thing I didn't like about my setup, and part of why I went back to stock. I didn't have the right barb fiting. -8an is rather large compared to the opening on a Walbro
Quoting LIV4PSI:
Highly evident you did over-torque them. Aluminum washers don't take much to seal. If they deform then either you reused them over and over, or they are over-torqued.
desant78
Clarksboro, NJ
Call JNZ Tuning. I was at the shop a few months back, and it isn't online, but they have a kit they use on customers cars for all new fuels lines in a vr4. I believe they know all the fittings, lengths etc needed for a vr4. Call up JNZ, ask about getting a kit for replacing lines, and I'm sure they will have everything you need.
Good luck!
marvinmadman
Thanks. I looked there first. Those washers look nylon in that pic BTW.
LIV4PSI
O-H-I-O
The ones on my car weren't aluminum, nylon sounds right. I would have said plastic /ubbthreads/images/graemlins/blush.gif
Prove It, I'm also not sure if I trust basic Jegs/Summit brand lines. I think that is part of the reason for the fuel smell on my Subaru. Plus the weird routing of lines. But since the OP has decided on Russell classic lines, it's another topic
marvinmadman
Quote from JNZ is $283 for just the feed side using off brand nylon 8an hose.
EHmotorsports
Beaverton
that isn't to bad. we spent about 600 in fittings and braided hose for the last setup we installed.
diambo4life
Edmond, Oklahoma
I'm getting ready to do a double in tank in mine and this is how I am going to set it up. I already have -8AN line going to the back of the car.
</font><blockquote><font class="small">Quote:</font><hr />
Summit Racing SUM-230606 - Summit Racing® Stainless Steel Hose SUM-230606
Hose, Braided Stainless Steel, -6 AN, 6 ft. Length, Each
(Mfr. #: SUM-230606)
Ready to Ship
Ground
$26.97 1 $26.97 (not pictured)
Summit Racing SUM-220690 - Summit Racing® Hose Ends SUM-220690
Fitting, Hose End, Straight, -6 AN Hose to Female -6 AN, Aluminum, Red/Blue Anodized, Each
(Mfr. #: SUM-220690)
Ready to Ship
Ground
$4.97 4 $19.88
Summit Racing SUM-220108B - Summit Racing® Y-Fittings SUM-220108B
Fitting, Y-Block, Aluminum, Black Anodized, -8 AN Male Inlet, -6 AN Male Outlets, Each
(Mfr. #: SUM-220108B)
Ready to Ship
Ground
$26.97 1 $26.97
Derale Cooling Products 98200 - Derale Performance AN Swivel Hose Barb Fittings DER-98200
Fittings, Swivel, Straight, Aluminum, Natural, Female -6 AN, Hose Barb 3/8 in., Each
(Mfr. #: 98200)
Ready to Ship
Ground
$4.99 2 $9.98
Aeroquip FBM2793 - Aeroquip Bulkhead Adapter Fittings AER-FBM2793
Fitting, 90 Degree, Bulkhead Union, -6 AN Male, Steel, Each
(Mfr. #: FBM2793)
Ready to Ship
Ground
$9.97 2 $19.94
If I was just doing a single intank....I would do the 90deg -8AN bulkhead fitting as seen here then get a -8AN to 3/8" adapter fitting like this one and you are good to go.
