FS: Holset, o2 housing, transmission, Valve cover, poly mounts, new pics!
thedsmguy
Vancouver Washington
02 housing (probably ebay) $40 as is, no cracks, has a plug where o2 goes, I have no idea why.
English racing built trans, Double sync 1st 2nd, just took it apart and replaced 3rds sync, and a failing spider gear. This trans is in great shape. $1500
HX35 Holset. Polished housing. In great shape. Misplaced he clamps to hold it together! I was told it was a 9cm housing (NOT BOLT ON) $400
Minty HE351 non VE turbo. No pics, but I can get some $500 complete again, not bolt on.
Shaved mitsu valve cover. Nice piece, a couple busted holes for the cover, no cracks or other issues. Needs paint! $50
Poly mounts timing belt, trans, and either the front or back, cant remember. From a gvr4 $125
VR4 pedal assembly $80
dash pod $35
Rear bumper support $40
Dummy gauge $10
No cracks, no bad holes Needs paint to be much nicer $60
2g/evo3 manifold. Has crack in the bottom. $35 shipped!
jnava
Arlington, Tx
grille, I'll take it.
thedsmguy
Complete turbo setup. Yes, ebay turbo, no it doesn't seem to have much play, just a thumbnail or so in and out. Worked fine, dyno'd at 350whp recently.
Whole setup, manifold, turbo, tial wastegate, downpipe all for $400 plus shipping (probably in the $75-80 range for shipping all of it)
English racing built trans, 1st and 2nd double synchro, taller 5th gear $1500 recently inspected great!!!
1g fmic core $100. A little beat up but not really that bad.
264/272 regrinds $150 shipped Not perfect, but not bad, these are USED but did not cause any damage to the head they were in.
Unpictured 264/264 regrinds $150 shipped as well.
Tail light center section $40
Dash pod $25
Uncracked, or stripped valve cover $50
non eprom dsm ecu $50 works.
1g fwd exhaust $250 nice setup
14b hotside nothing special, 1 broken bolt, mild cracking. Still very usable with the broken bolt removed $40
1" 5x114 wheel spacers $50
SSGdave
San Diego, CA
Quoting thedsmguy:
/ubbthreads/images/graemlins/ooo.gif HAY! would you be interested in seperating that Turbo kit. IF SO, i will take the manifold, and tial wastegate right now. LMK!
SSGdave
San Diego, CA
...PM Sent
IncorpoRatedX
Arizona
who did the regrinding on those cams? Im interested in the 264 combo
