I've been looking at a couple newer cars/trucks and just can't keep 5 cars. Something has to go. I've offered it up locally and had a lot of calls & PMs but no $ in hand. Keeping my Talon and 3000GT VR4 running takes a lot of time. Maybe someone can give some love to this GVR4 too. It's been my daily driver for a few years. It drives, handles & shifts great.
Body/Interior:
#1587/2000
'91 green Galant vr4 turbo AWD 5 speed.
Cruise, PW, PDL, power 2 way Sunroof, PS, PB, PM, ABS disconnected (bad wheel sensor prob)
Body is in good shape - some seam rust at the bottom of the front doors.
Typical rock chips for it's age.
Pin stripe needs to come off.
Black leather interior - good shape, small tear @ corner of driver's seat.
WORKING R134A converted AC, new compressor and many ac parts.
1g steering wheel.
Tinted glass.
Engine/powertrain:
~150k chassis miles.
~23k miles on a rebuilt longblock mostly assembled by me.
6 bolt, .020 over Wiseco 9.0:1 forged pistons, free floated wrist pins on modified 1g big rods.
BSE kit.
Full engine gasket kit (an occational drip but no leaks).
Jim Stewart racing engines head w/ Ferrea valves, JAM spring kit, Ti retainers, bronze guides, casting flaws removed, stock c/d cams.
Mitsu MLS head gasket w/ ARP studs.
GT3076RLE ball bearing Garrett/Mitsu hybrid internally gated turbo.
2g exhaust mani.
2g O2 housing.
2.5" turbo back exhaust.
eBay FMIC.
2.25" pipe kit.
2G TBE.
Electronics/ECU/fuel:
"Hop" chipped 1G ECU running pump gas @ ~24psi. Studder box, NLTS, no fuel cut, 2x logger, etc...
2G MAS.
Innovative LC-1 wideband O2 w/ very nice Innovative display gauge. ***Car is running OPEN loop mode right now. I'll install a new OEM O2 sensor if I don't sell this with the car. Negotiable.***
880cc PTE injectors.
Magnecore wires.
NGK plugs.
Walbro 255HP fuel pump (needs new tank seal, leaks gas if topped off)
-6AN braided filter to rail.
BR AFPR with mechanical fuel pressure gauge.
PC680 small battery (needs a new tray).
AM/FM/Cass/10CD changer - icky Sony head unit.
Programmable turbo timer - nice!
Dual gauge pod + one on the steering column: boost, EGT, ***maybe the wideband listed above***
Wheels/Tires/Suspension:
2 sets of 4 lug rims and tires. Stock w/ M+S tires, aftermarket 5 twin spoke knock offs w/ T1R tires. Good tread on both sets.
Hawk pads.
China cross drilled rotors.
AGX shocks.
Lowering springs.
Poly body bushings.
Rear steering delete.
Stock 5sp tranny rebuilt by Josh Forbing (previous owner). Shift great, no grinds.
CFDF clutch w/ relined "ACT" like street disk. (can't hold the torque, slips once in a while. see clutch options below)
I will throw in a brand new Clutchnet sprung hub 6 puck disk.
We can negotiate for one of my other clutches though:
***optional ACT 2600 old style pressure plate (~30k miles)***
***optional ACT chromolly flywheel (4k miles)***
***optional ACT 2900 old style pressure plate (4k miles)***
***optional ACT old style street disk (4k miles)***
AGX shocks w/ EVO lowering springs.
Known issues:
stuck antennae
needs a fuel pump / tank gasket (or just don't fill it 100%)
ABS unhooked (bad wheel sensor somewhere).
Occasional idle surge (FIAV blocked off, ISC good)
Needs a better battery tray.
Needs a better coil bracket (BR regulator was cutting the plug boots when in the stock location)
An S-AFC would be nice but not needed. It's a touch rich at cruise but I can reburn the chip if you'd like.
Josh removed the front bumper when he installed the FMIC.
I'm sure I'm forgetting something. Lots of receipts and paperwork comes with the car. I also have a few spare parts. I know the 2 previous owners. I also have a carfax saved somewhere.
I'll get the car washed and cleaned up before adding more pics. This one will have to do for now:
Contact info:
John Hopkins
(317)373-8602 cell
Body/Interior:
#1587/2000
1g steering wheel.
Tinted glass.
Engine/powertrain:
BSE kit.
2g exhaust mani.
2g O2 housing.
eBay FMIC.
2.25" pipe kit.
2G TBE.
2G MAS.
Magnecore wires.
NGK plugs.
Hawk pads.
AGX shocks.
Lowering springs.
Poly body bushings.
Known issues:
stuck antennae
Contact info:
John Hopkins
(317)373-8602 cell
