FS: Built Engine plus other goods
OZRally
Selling a nicely built Evo 9 piston with 6 bolt rod setup. It's a full short block minus a water pump and oil pan. Full arp hardware, ACL race bearings, oil squirters and bs delete, standard polished crank, full assembly was balanced. Can include OE 4 layer headgasket and 6 bolt oil pan if the price is right. Retails at $1800 without shipping. Give me your best offer.
4 bolt rear end for 1g. Has cups, axles and mustache bar.
GVR4 front axles.
1g rear calipers good condition.
Stage 3 Keydiver chip for 750cc injectors. SOLD
Clutch master and slave.
Plus more goods will be available if I end up parting out my car. Make an offer on all items. Need to clear up space and make some cash.
turbojew
Dallas, Tx
How many miles on built motor? what were hp numbers? Comp Ratio of pistons?
johnnyRacer
Tampa, FL.
How much for the gvr4 front axles? What condition are they and where in Illinois are you? I'm in the windy city.
OZRally
Quoting turbojew:
Motor has 0 miles, pistons were grabbed from an Evo 9 with only 15k and rods are reconditioned and fairly new. Compression ratio is that of the stock Evo 9 pistons, 8.8:1.
OZRally
Quoting johnnyRacer:
The front axles are in great shape and the driver side comes as a full assembly with the center bearing/bracket. I'm in the NW suburbs, Schaumburg. Looking to get $60 for both.
