FS: Boost gauge, ARP, turbosmart, and more! prices updated.
thedsmguy
Vancouver Washington
7 bolt 11mm ARP headstuds new, never used $75
Turbosmart dual stage boost controller USED $120
Autometer ultra lite II 35psi (no vacuum) $30
1g abs delete kit $75
walbro 255 fuel pump $50
1g awd front axles $50
Injector resistor boxes $20 each GVR4 specific bracket available
Nice 7 bolt oil pan $25
Nice 6 bolt oil pan $25
Front (oil pump) cases $50
stock flywheels $40
GVR4 wiring harness missing 3 connections at the thermostat area $120
GVR4 wiring harness with some hacks into the ecu plugs for a afc $100
rear strut bottoms from awd dsm's $25 set of two.
Plus I've been parting out multiple 1g dsm cars. Please ask me for anything you ever need, I'll be prompt to tell you if I have it or not.
This is probably 10% of my total inventory but a large amount of the aftermarket things as those sell really quickly.
Thanks,
Paul
Alex
Alaska
I might need the upper portion of the 1g steering rack.. meaning the short half part that bolts to the steering wheel.
