FS: 91' TSi part out
Drew84
Peabody, Ma
Right now I've got these parts pulled and ready to go. There is more stuff on this car but I have yet to pull all the parts. It is a factory sunroof car. Mostly a lot of trim parts. If you don't see some thing, ask. It may be on the car and I can pull it a la carte. This car does not have an Engine, Trans or Engine harness as that went into #801.
All prices are obo, I can ship for extra money.
2 sets of tail lamps, Left, Right, Center $20 each.
Front side markers Left, Right, $10 each
Rear red rectangle side markers $5 each
Front head light pass throughs $20 each
Rear Motor mount with poly bushing, rusty but I can sand blast it and put some black paint on it. $20
Trans mount with poly bushing, Same thing, rusty $20
Timing belt side motor mount Poly bushing, slightly rusty $30
Front to back pass side sub frame piece $30
Front to back driver side sub frame piece $30
Radiator, no shroud, plastic end tanks looks decent $50
91' shifter cables, base and shifter $80, they have skate bearings in the end.
Coolant over flow tank, $10
Rear hatch trim, $10 each for the big parts, $5 for the small panels.
Light gray leather interior $200 for all the seats
Center console carpet parts, $5 each
Trim around shifter, $5
Center dash trim around radio $10
Glove box, has a nick in it $10
Gauge cluster $30 131k
Left and right door panels $20 each
holeshotmoe
MD
I need this part in gray for a 90 eclipse. Do you have one and do you know if the tsi part is interchangeable?
Thanks
spooln4fun
Belpre, OH
Can I get some pics of these please?
Drew84
Peabody, Ma
Correction, I actually have the trans,front engine mount and timing belt side mount.
I do have the steering rack, I am unsure of the condition. It had the lines taken off and has been exposed to the weather.
I do have that dash part. I have to see how to remove it.
Sorry I missed this questions.
ttt
89Mirageman
Stantonsburg, NC
Quoting holeshotmoe:
Thanks
That is the actual dash itself, its not separate. I know because I just replaced mine on my 92 Eclipse because it was cracked. FYI
holeshotmoe
MD
Quoting Drew84:
...I do have that dash part. I have to see how to remove it.
Wow, if that piece is locked to the dash it might be a pain to package well and expensive to ship. Mine has a crack in it as 89Mirageman's did. Ugh!
Drew84
Peabody, Ma
I still have a lot of stuff left on this car. 5 lug hubs, Gas tank, I have a sending unit.
Drew84
Peabody, Ma
Five lugs are sold,
In the course of pulling the five lug hubs out. I have the 3 bolt rear end out $100, and 1g AWD gas tank for sale now $100. The sending unit is junk.
