pot
This is a part out for the following vehicle:
- 1991 Galant vr4 badge number 1335/2000 with 216,909 miles
- VIN: JA3CX56U4MZA010336
- Model: E39ASNPFL2M
- Color, Interior Option: X68
*All parts prices include PayPal fees and shipping costs for CONUS based transactions. I accept all payments via PayPal to: [email protected]. If interested please contact me via PM or mobile no (910) 689-6150. Thank you for looking!
Coolant Overflow Bracket $15.00
Radiator Fan Blade $20.00
Radiator Bracket $15.00
Driver Engine Mount Bolt $8.00
EGR Valve $20.00
Fuel Pressure Regulator *Factory $12.00
Fuel Feed Line *Factory $8.00
Fuel Pump Wiring Cover $8.00
Fuel Rail $20.00
Rear Lower Timing Cover $15.00
Rear Upper Timing Cover $15.00
Tensioner Hardware $3.00
Throttle Body Elbow $15.00
Water Pump Pulley Set $15.00
BODYAir Guide Panel $5.00
Air Inlet (Passenger Side) $15.00
Cowl Panel Hardware $3.00
Front Windshield Trim $40.00
Door Hinge Set $30.00
Door Pin Set $3.00
Horn Set $20.00
Hood Latch $15.00
Hood Release Cable Guide $12.00
Driver Hood Hinge $12.00
Fender Hardware $3.00
Front Driver Dogleg $65.00
Hood Bumper Set $3.00
Fuel Filler Door $20.00
ECU Harness Retainer $3.00
Alarm Horn Relay $12.00
Weather Strip, Interior Rear Passenger $20.00
Exhaust Hanger Set $15.00
License Plate Lamp Set $15.00
Trunklid Striker $5.00
Rear Bumper Support Bracket $20.00
Instrument Cluster Mount $15.00
ETACS Computer (part no MB852353) $50.00
Control Unit Auto Seat (part no MB617345) $40.00
Sunroof Control (part no MB543075) $30.00
Sunroof Relay (part no MB627895) $12.00
Horn Pad $20.00
Passenger Dash Speaker Cover $15.00
Refractor Mounting Bracket $30.00
Refractor Mounting Bracket Set $15.00
Front Door Sill Set $20.00
Rear Door Sill Set $20.00
Foot Rest $15.00
Defogger Switch $20.00
Sunroof Felt Trim $25.00
Sunroof Shim Set $5.00
Driver Kick Panel $15.00
Buzzer (part no MB561626) $15.00
Door Card Clip $3.00 each
Door Ajar Switch $12.00 each
Interior Door Handle $8.00 each
Headliner Handle $8.00 each
Front Lap Belts $20.00 each
Seatbelt Trim A $3.00 each
Seatbelt Trim B $3.00 each
Gas Pedal $30.00
Driver HVAC Vent Tube (part no MB439025) $15.00
HVAC Vent $3.00 each
HVAC Vent Tab $1.00 each
Glove Box Frame $15.00
Glove Box Reinforcement Bracket $5.00
Glove Box Stopper $3.00
Glove Box Striker $3.00
Seat Bolt Cover $3.00 each
Glove Box Latch Bar $15.00
Shifter Cable Clip $1.00 each
Interior Weather Strip, Passenger Front $15.00
Amplifier Power Adapter part no MB665345 $30.00
Wiring Harness Cover, Passenger Rear $12.00
Seatback Trim A. $8.00
Seatback Trim B. $8.00
Trunk Dome Light $8.00
Trunk Trim $20.00
Trunk Weather Strip $20.00
Trunk Access Trim $15.00
DRIVETRAIN
Clutch Switch $15.00
Reverse Sensor $15.00
Clutch Line to Slave Cylinder $12.00
Clutch Line to Hard Line $12.00
Shift Selector $15.00
ABS Hydraulic Unit $125.00
ABS Connector Bracket $10.00
ABS Proportioning Valve $40.00
Rear Wheel ABS Speed Sensor $25.00
Parking Brake Cable Retainer $12.00
Rear Brake Caliper Bracket $40.00
Power Steering Return Tube $25.00
Cruise Control Cable Retainer $5.00
Rear Subframe Stud $30.00
Rear 4 Lug Hub $50.00
Rear Sway Bar Bracket $15.00
Rear Strut Mount Cover $15.00
ENGINE
GM Alternator $75.00Coolant Overflow Bracket $15.00
EGR Valve $20.00
Fuel Rail $20.00
BODY
Door Pin Set $3.00
Horn Set $20.00
Hood Latch $15.00
INTERIOR
Horn Pad $20.00
Foot Rest $15.00
Gas Pedal $30.00
Trunk Trim $20.00
DRIVETRAIN
BRAKES
ABS Computer (part no MR606759) $80.00
STEERING & SUSPENSION
Front Power Steering Rack Bracket $15.00
HVAC
Blower Motor $65.00
