loser3000
I have my long wanted/dream project up for sale. I've been jobless for too long now and now its time to part ways so I can try to stay afloat.
Ok, story about the galant. I bought it 4+ years ago as a engine fire victum so I could to rebuild it the way I wanted. The hood isn't the one that got burnt, but the DS fender does have a small bubble from where it got heat.Since then I pulled the engine bay all apart and getting ready to repaint the engine bay. Then I pulled the dash to pull the engine harness and AC core. Thats how its still sitting today.
Heres the parts I have for it (and ones to replace the burnt parts);
VR4 front chassis harness
'91 e33 front chassis harness (less alarm wiring, but no foglights)
VR4 engine harness
DSM engine harness
Splice-able DSM Auto tranny harness with correct two plug chipped TCU
Galant auto shifter, cable, and console plate
Galant auto pedal assembly already bolted in with new booster and master cylinder/resivor
Galant manual trans shifter and cables
DSM shifter and base
Non-abs galant brake lines and DSM awd proportioning valve
Used set of '89-92 headlights and turn signals
Uncracked foglights
'89 and '92 griles
5 lug dsm front spindles bolted on
5 lug rear hubs with trailing arms in trunk
3 bolt LSD manual rear diff with axles (not installed)
3 bolt LSD Auto rear diff (not installed)
'93 DSM automatic transmission with shift kit (130k before I removed it myself)
-will need 6 bolt flexplates still
Auto DS half shaft and both CV axles for cores
Auto transfer case
'91 dsm tranny with unknown miles and transfercase
'91 6 bolt turbo motor to go with it. It was in my friends car that he just rebuilt and put 200 miles on. Then it backed the oil filter off of and developed a rod knock on #2 cyl. He bought a new motor so I got this one. I picked up a STD crank to replace it. It didn't spin the bearing so the rod big end was checked out and was still in perfect "roundness". The pistons/rings are 20 over toplines and all original machine work was done by Moffitt and Bratton locally. The block was flushed. I also have new STD crank and rod bearings to put the short block back together. I think I may have a head to throw in too. It will need a oil pump and other timing related parts.
And boxes of engine and underhood parts to put together a full motor or two.
Also with it is a beat factory roof rack with trim strips
Aluminum reproduction 837/2000 plaque with key fob
Double din aluminum dual gauge holder with serial cable holder
'89 black glove box and '89 black DS knee panel with duct
GS no wing trunk
And the leather isn't crack and I make it point still go out and condition it. Its just not as supple as it could be. I don't think any seams are coming apart.
Its plently rollable right now with 4lug spares in the back and 2 of the 4 DSM wheels for the front.
I don't want to part this out. I really want to see someone either finish the auto setup. I'll try and work with someone to get this to a good home. I can clear anything out and take more pictures of what ever you want.
When I bought it:
Got it home:
As it sits now in the back of the shop with its parts all around it:
VR4 engine harness
DSM engine harness
Uncracked foglights
'89 and '92 griles
Auto transfer case
GS no wing trunk
When I bought it:
Got it home:
