Up for sale is car 774/2000. The Car tuned by Erkle at Tach Motor works and the car runs great. I've put so little miles on it since I've owned it and it's a shame to watch it sit. I have numerous projects and unfortunately this one has to go. All performance bolt ones have less than 100 miles on them. Please pm with questions and offers. I haven't figured out how to add pics from my apple device my apologies. I'll gladly send pics via text 917-533-4963
Engine:
-Ross pistons
-Eagle Rods
-Calico engine bearings
-Balance shafts removed
-New oil pump and water pump
-Power Enterprise timing belt
-Ported Head
-SI dual valve springs
-ARP everything
-Mitsu MLS headgasket
-Forced Performance 272 cams
-Mocal 13 row oil cooler
-300m COP setup
-Royal purple 10w40 and OEM Filter since I've owned it
Exhaust:
-Evo III ported exhaust manifold
-Evo III ported O2 housing
-3" Stainless V-band downpipe
-3" ATR Pitbull exhaust system
-HKS Standard external wastegate
Turbo:
-Holset super 40
-Stainless braided oil feed
-BEP housing
Intake:
-Magnus sheet metal intake
-Magnus heat barrier gasket
- S90. 70mm throttle body w/block off plate
-K&N 12" filter
-2.5 intercooler pipes 3" to throttle body
-Spearco intercooler/Buschur 1g street version
-4" Forced Performance intake pipe
- Tail BOV purple 11psi spring
Electronics/engine management:
-AEM EMS
-AEM Tru Boost with 5 bar map sensor
-HKS turbo timer
-AEM wideband
Fuel system:
-Walbro 255lph HP fuel pump
-Aeromotive AFPR
-SS -8an lines from tank to rail
-1200cc precision injectors
Drivetrain:
-Dogbox racing stage 3 trans w/ welded diff 23 spline
-Rebuilt transfer case 23 spline
-ACT 3200lbs with 6 puck sprung race disc w/extended push rod
-Fidanza flywheel
-4 bolt rear
-Entire driveline rebuilt
-Driveshaft carriers
-U-Joints
-Slave cylinder
-Master cylinder
-Shifter cables
-Fork and ball
Suspension:
-Whiteline springs
-KYB AGX adjustable
-Front and rear strut bars
Brakes:
-Front and rear cross drilled and slotted
-Rebco metal matrix pads
-SS lines
Wheels/tires:
-17" Racing Hart C4's
-Kumho Escata's 215/45/17
-All stock no rips
-MOMO Racing steering wheel
-Stock Paint
-93 headlights
-Powder coated lime green valve cover
-Modified 1g motor mount
-Prothane mounts
-Power steering removed
-Relocate battery to trunk
-New PPG windshield
Engine:
-Ross pistons
-Eagle Rods
-Ported Head
-ARP everything
-300m COP setup
Exhaust:
Turbo:
-Holset super 40
-BEP housing
Intake:
-K&N 12" filter
-AEM EMS
-HKS turbo timer
-AEM wideband
Fuel system:
-Aeromotive AFPR
Drivetrain:
-Fidanza flywheel
-4 bolt rear
-U-Joints
-Slave cylinder
-Master cylinder
-Shifter cables
-Fork and ball
Suspension:
-Whiteline springs
-KYB AGX adjustable
Brakes:
-SS lines
Wheels/tires:
-All stock no rips
-Stock Paint
-93 headlights
-Prothane mounts
-New PPG windshield
