front right axle removal help
kitcho
canada
I'm trying to get my badly worn front right axle replaced on my vr4.
I'm following this guide that i found on dsm tuners
Method 2
Turn the steering wheel all the way to the side you are working on (this will pull the tie rod towards the center of the car). Remove the drive axle cotter pins and nuts (this will require someone to step on the brakes while you use a long breaker bar to loosen the nuts, disregard if you loosened the nuts earlier), brakeline bracket from the strut, and lower strut bolts. Then slide the hubs away from the outer axle spline leaving the axle shaft still connected to the transaxle. Then remove the whole axle shaft. For the passenger side, there is a metal ring clip on the end of the axle. To pull the axle, put a large screwdriver or prybar between the axle end and tranny, and give it a quick jerk. It should pop the clip loose and then you slide it out of the tranny.
I am having a lot of trouble getting the axle end off the hub though. I can *almost* slide it out, but i just can't rotate the hub enough fully take out the axle from the hub. What am i doing wrong?
SouthCaliVR4
North county San Diego
try using a pry bar to push down the lower cont arm or dissconect the swaybar end link, it is going to be a barely squeak by kinda thing no matter,just keep wiggling angles till it comes free.
cspetros
Port Norfolk, VA
When I did this, I ran into the same problem. If you turn the steering wheel all the way to the opposite side (away from the side you are working on), though, I the axle will clear. This worked for me.
kitcho
canada
away from the side you are working on?
I rotated the wheel all the way towards the side i was working on like the guide said. Should i turn it the other way?
btw, i already drained my trans, so I don't think i should run my car (to rotate the wheels) until i fill it again.
cspetros
Port Norfolk, VA
Yes, 'away' from the side you're working on (rotate steering wheel counterclockwise in this case). Doing so extends the tie rod towards the side you are working on, allowing the hub enough room to swing aside and clear the axle end. This worked for me when I removed the front right {passenger side} axle. I didn't have to do this with the drivers side.
Rotating the wheels? You should be able to turn the steering wheel without having the car on; it's not necessary to spin the wheel.
Good luck /ubbthreads/images/graemlins/smile.gif
kitcho
canada
i got it! thanks cpetros for the tip, that did it.
now to remove the trans side
wish me luck
kitcho
canada
any special precautions i should take to mount the new axle?
i've heard you're supposed to lubricate the c-clip. how can i be sure that i mount the axle correctly?
thanks
kitcho
canada
sorry for posting in here again so soon, but i have to ask
what's the trick for getting the c-clip to go in like it's supposed to? I'm having a heck of a time trying to get the axle to go in all the way.
cspetros
Port Norfolk, VA
When I did this for the first time, I called a mechanics shop and asked. They said to just hold the axle straight, and smack the end with a heavy mallet. The force is just enough to pop the clip and let the axle go in, without damaging the CV joints. I'm not sure how others on here do it, but this has worked for me.
Barnes
Richland, WA
That and lube up the c-clip, and IMO the entire axle stub. But yeah, sometimes you have to pound that SOB to get it in there.
rgeier11
Chicago Suburbs, IL
I use a 2x4 along the green part of the axle (your color may be different) and hit it with a hammer.
SouthCaliVR4
use a mallet on the very end. if you hit the inboard joint you risk ripping the boot. make sure if you're using force that you are solidly in the splines & only using a bit of force to seat the snap ring or you can damage your final drive.
