Front Evo strut 1° camber adjustment bolt
467
Fremont Ca
I couldn't find this with search so I hope it isn't a repost. This page claims that the stock top 19 mm bolt on the Evo struts have 1° of camber adjustment. See lines five and six here. click Anyone know if this works for our knuckles if they're drilled out and used with the evo strut?
tektic
ronkonkoma, ny
I don't own an evo but its likely true if its documented. However 19mm diameter bolt seems like a typo. The galant is m12x1.25. I only assume the hole on the evo is 14mm. Best measure it to be sure. If that is the case, drill out knuckle to 14mm and get these. Or one of the many similar products. If more adjustment is needed then you can order two a side.
It's a 19mm head, the shank is 14mm. I use them on 715, drilled knuckles and all. Yes, they are adjustable, but not much and with Evo struts on the GVR4, you need more than 1* adjustment. Plus it's just an offest type bolt, you can't dial in more or less camber. I tried them, but I plan on getting real camber bolts instead.
