Did you have an issue with the comp cover pointing directly on the front motor mount? I couldn't even get a 90 degree coupler on there. I ended up clocking the cover about 12-15 degrees and modifying the wastegate actuator bracket. I'm sure FP will say I voided the warranty, but it wouldn't fit otherwise. Are the 1g motor mounts different? For a plug & play turbo, this install is more time consuming than I expected.
Mine is externally gated, so I can't help you there. I clocked the comp housing considerably to better suit my piping. I also had the comp housing modified with a weld on elbow.
The front mount bracket on a 1G is different though, would probably give you about a half inch extra to work with, but that info is useless because you have to use the galant bracket.
Back when I had mine, the only issue was that I had to clearance the water pipe to fit the compressor housing. I also had mine clocked upward like Justin and used an external wastegate. No need for a smaller radiator. Hell, I even used the stock radiator fan with a 3" intake pipe.
No confusion. It's in, clocked comp cover, internal gate with modded actuator bracket, mounted like a 20g, stock fan and 3" intake. I may go for a drive tonight. Thanks for the replies.
Went for a drive. It needs a tune. Left it on low boost (15 psi) and saw knock on some pulls and none on others. This is on a 2.3 and the previous turbo was a big 16g. Very different.
I don't have any pics of the competed install yet, but here are a few of the process:
I cut a hole in the sheet metal where the stock battery used to be and used a 4" 90* silicon elbow connected to a K&N filter in order to put the filter in front of the plastic fender liner for a cold air intake.
